Hi guys.
Would really love some help here.
I just got a brand new computer - 4670K + Gigabyte Z87x mobo. BIOS is F7.
Ran a Windows 7 64b install - all smooth, no issues or hiccups. After booting windows - the network is dead.
Setup:
1. Tp-Link Router - working properly, all other devices (including 2 phones, iPad and a laptop) are connected properly via WiFi or Wired (for laptop)
2. The wired connection is via Power Adapter (again, laptop connected to it works absolutely fine immediately upon connection)
Issue:
The new computer won't connect using the Power Adapter.
What I tried so far:
1. Installing and re-installing drivers both from the disk that came with the mobo and the latest downloaded from Gigabyte website
Side notes:
Power Adapter is http://www.tp-link.com/lk/products/details/?model=TL-PA211
When all is well - all the lights are on and the 2nd and 3rd are blinking (2nd sparringly).
In my case: in Windows and in BIOS - the 3rd one doesn't light up. Link is set to AutoNeg, but setting it to anything else (100mbs full, half etc.) doesn't help either.
Additionally, link status is marked as disconnected and I can't change it.
Any help is greatly appreciated.
EDIT:
running diagnostics from the device manager:
1. Hardware test works fine (Register, EEPROM, FIFIO, loopback)
2. Cable is reported to have poor quality at 2meters - the same cable that works fine on the laptop. Replacing it doesn't do anything.
Can Power Adapter be somehow incompatible with NIC?
Setup:
Issue:
Side notes:
EDIT:
