Home Depot sells Ethernet cable by the foot. They'll cut a length off a reel for you.
Be aware that faster ethernet connections are limited to about 100m in length. If it happens to run over that you'll need a repeater. I know that your length falls within that, but I also know that network designs often don't survive contact with the real world. 🙂
