Network Cable termination to keystone and RJ45
kamaran
I'm trying to install an outdoor IP CAMERA.
I'm trying to run a cat6 from a wall panel keystone on one (X) side and an RJ45 (Y) connector on the other end to the IP camera.
All connected correctly via the 568-B Wiring wiring method, however when I test with a LAN cable tester nothing is working??
Into the testing tool I'm connecting the RJ45 end (Y) and another cable connected to the keystone (X) which should effectively create a working cable?
Any ideas?!
problem solved - I had wired the RJ45 crimped side left to right instead of right to left.
Thanks everyone.
