NETWARE 5.1 console one problem. Help me uninstall the program from netware.
Grminalac
1,149
After installing 5.1 I applied sp5 restarted; installed the java update; restarted and then applied the console one 1.34a update. (from 1.2c)
However now whenever consoleone loads and I login all i get is the my world icon. Clicking on that does nothing.
I saw in novell technical support that there is a similar problem caused by 1.2c but it is remedied by upgrading to a newer version. 1.2d or better. Also the problem is caused by groupware which i am not running anyway... Since I upgraded to 1.34 this should not be a problem.
One other item of note is that the consoleone splash screen still displays 1.2c but the program appears to be 1.34a as it incorporates new features not available in the older version.
What i would like to do is manually uninstall consoleone from netware and then reinstall it fresh. However i have no idea how to do this and am finding no help at all online in any documentation.
Thanks
Grminalac
1,149
I just deleted the entire consoleone directory, then installed then it worked. thanks anyway
