netscape problems
Crymsonap
was hoping someone could help me...some websites simply do not load on my computer (ie. yahoo, ebay, ANADTECH!!). it's not a connection problem, as i use the same connection on two different computers and one computer loads the webpages just fine. please let me know what to do. netscape and internet explorer do not load those pages.
sandorski
70,705
6,261
How are your computers connected to the net?
Is the computer that is having problems an ICS server or client?
Crymsonap
i don't know how to check. the computers are not connected to each other. my dial-up doesn't let me get to those websites either. please let me know what to do. thanks.
Kueay
Banned
Apr 15, 2001
142
What you need to do is reconfigure the coaxial partition with the variance of the HD, Thus enabling the router to bipass the transmition mainframe..
fairly easy if you ask me.
GregMal
1,427
Which version of Netscape are you using?
Check your Advanced preferences so that cookies are enabled and
JAVA is enabled......
Greg
