- Sep 30, 2001
- 12,684
- 2
- 81
So I have a 16 port netgear switch, a modem, and a router attached to a 300va UPS.
Anytime the UPS switches to battery mode the switch looks like it reboots and then all 16 port lights start going into a synchronized blinking status and all connections are lost.
Are their known issues with switches and UPS batteries?
Does the switch need to be on it's own UPS?
Or is this just a typical problem with the lower quality of a Netgear consumer switch compared to an Enterprise level switch?
The whole point of having the UPS there is so that when the power does go out... we don't lose our network.
So if this turns out to just be a problem with the switch itself then I will be looking to upgrade the switch with a low-cost solution, that will allow future expandability.
Any ideas?
Thanks
Any ideas?
Thanks
