- Mar 30, 2020
- 38
- 7
- 41
- NEAT & TIDY: No more messy cables!! Our integrated cable management will keep your office and home neat & tidy with no more tangled cables causing an unsightly mess.
- SLEEK AND STYLISH: The round shapes and slim design will match any decor, and our lightweight design allows the switch to be mounted anywhere.
- SILENT & INVISIBLE: Don’t allow that any blinking light disturb your movie, work or sleep. Just push the Port LED button and any flashing light will be turned off, also the fanless design will keep the switch silent.
- PLUG-AND-PLAY: Simple set up with no software or configuration needed
2 x 10G / Multi-Gig Ethernet
8 x Gigabit Ethernet LAN Ports
Up to 20 Gbps LAG
Get real-time insight on performance and configuration
Personalize every light on your switch for better visibility
