Hello,
I got my new MR314 router last night and I am having a few problems with it.
My network config is as follows.
I have RR with 2 live IPs. I am currently running an FTP server on one IP which is connected to Netgear DS104 hub. From the hub I have uplink to the MR314 which then splits out to hardwired 2 PCs and 1 wireless laptop.
Everything works great, I get all the proper IPs' and access to the Internet from all the devices.
My problem is that when I FTP into my external PC I receive LAN speeds of 600+KB/s, however after transfering about 350Mb's the speed drops to 40KB/S which is my RR default send speed.
The only way I can reset and get back to LAN speeds is if I pull the power on the MR314.
Is there anything in the config that I need to change that could be causing this issue???
Thanks
Thanks
