Netgear FA310TX 10/100 card not autosensing a 10BT connection...
Jugernot
6,889
I have two computers (one with ISA 10BT & one with the netgear 10/100) hooked into a Intel InBusiness 8port 10/100 switch and they only successfully connect up if I manually set the FA310TX card to 10BT to match the ISA card's speed. If I set the FA310TX to Autosense 10/100, the computers loose their connection.
Could the drivers Windows 2000 provided be the problem? I checked Netgear's page, but they say "Included with Windows 2000".
btw: When I switch the FA310TX to 10/100 autosensing the LED of it's port turns orange rather than the green of the ISA 10BT card. If I switch it down to 10BT, they are both green again.
Anyone suggestions?
Thanks,
Jugs
Mday
18,647
"I have two computers hooked into a Intel InBusiness 8port switch and it only works if I manually set the FA310TX card to 10BT. If I set it to Autosense, the computers have a connection."
what?
