Netflix App for Android*!
zoiks
11,787
The quality is fine on my Nexus S. Will this work if I were to travel abroad and connected through wifi?
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
App works on the Droid 1 stock froyo, but won't stream movies. Supposedly it works fine streaming with custom GB roms though.
Does not work at all on my Vibrant though.
ponyo
19,688
2,811
It'll work on the Droid 1 and the Vibrant if you're running 2.3 Gingerbread. The key to getting it to work on current unsupported devices seems to be 2.3.
alent1234
3,915
can't even download for my Inspire
what is the big deal with supporting more phones since most are pretty much the same hardware just different names
poofyhairguy
14,612
318
Part of me is glad this finally exists, but geez does it eat battery. Unlike the Yotube app which uses the DSP, this app doesn't seem to. On my Nook Color it leaves my CPU pegged (like when watching Hulu) which means that I would be surprised if I could watch Netflix for three hours.
Spoooon
11,563
203
Works on my OG Droid/CM7. As above, picture quality isn't as good as HQ Youtube/Vevo IMO. Have Gangs of New York going via 3G. See what happens to the battery life.
AstroManLuca
15,628
I'll have to get my wife to download it on her Evo. Too bad it doesn't support my Epic (yet). But her Evo does have a larger screen and a kickstand.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
*sigh* If you had been following this at all, or just merely googled a bit on the subject, you'll find out quickly that it's limited to very specific hardware because of DRM needs dictated by the MPAA. People are finding work arounds to get other devices to use it, but officially there aren't a ton of supported devices. It's not because of slow hardware, it's because of encryption and hardware DRM.
hanoverphist
9,867
23
i hope they push the dX OTA update to gb soon so i dont get the bug to root and rom this sucker just to play with netflix app. i bet when they do there will be some block from vzw anyway
quikah
4,228
770
There is no hardware DRM requirement (at least not with this version). If there was you wouldn't be able to stream on unsupported devices.
