Netbios over TcpIP problem
Bibble
1,293
My uncle has a crappy old Dell 2400. Recently, he restarted his computer and then he was unable to connect to the internet. The ethernet icon on the taskbar is stuck on 'acquiring network connection'. No matter how long he leaves it, it does not change from this status. If you unplug the Ethernet cable from his computer, it does indicate that it's been unplugged, so at least it notices that.
Anyway, so I think this problem has something to do with the NetBios over TcpIP driver. When I go to device manager there is a yellow exclamation point and if i go to properties it says "This device is not present, is not working properly, or does not have all its drivers installed (Code 24)."
I've reinstalled the drivers off the Dell drivers cd, but this did not solve the problem.
What can I do to solve this problem?
RebateMonger
11,588
Originally posted by: masteryoda34
My bet is that the ethernet port has just died. Pick up a cheap PCI ethernet card, should solve the problem.
Could be. I've seen the network ports die on a couple of the 2400-class machines.
Bibble
1,293
My uncle put in a new ethernet card, but the problem persists. Any ideas?
bwatson283
1,062
Make sure he didn't plug the cable into the same one by accident. Remove the old Card (if you can). Reset the TCP/IP stack (google it). Try a new cable. Linux live CD like suggested.
Pantlegz
4,631
4
try to manually set the IP, I had an old router where the DHCP would go to shit randomly. Also try a different port on the router, it could have gone bad too.
ASK THE COMMUNITY
