- Mar 11, 2000
- 24,149
- 1,795
- 126
OK, I couldn't get my file shares working with a friend's laptop without installing NetBeui. I only did that because I didn't want to mess too much with his LAN settings and NetBeui seemed to work fine.
Some questions.
1) Since NetBeui broadcasts everywhere, does it essentially defeat much of the purpose of a my Linksys router's ports? (Not that it would make a huge difference, since I'd only have at most 3 computers.)
2) I know NetBeui doesn't like routers, but can it cross a simple bridge? I want to run HomePNA for my laptop. Both my serving PC and my laptop will be behind the router. However, between the laptop and the router will be my Ethernet-->HomePNA bridge.
3) If I map the desktop drives on the laptop, will I need to remap it when I switch to LAN mode from HomePNA mode? When I'm in my home office, I'd just plug my laptop directly into the router. If I'm anywhere else in my house then I'd just plug into a phone jack. Hopefully I will have to change no networking card settings, because the PCMCIA card I bought for the laptop is doing both the Ethernet and the HomePNA, and is supposed to auto sense which is which. (It's the Linksys HomePNA Ethernet combo PC card. It does seem to work, at least for sensing Ethernet on my friend's computer.)
4) Is it safe to assume NetBeui won't work over an Ethernet-->wireless bridge? I say this because the 802.11b bridges by design function as mini-routers.
5) Are there significant security issues with NetBeui? If I set the permissions properly with the shares should I be OK? I'll try to figure out how to set up the logins soon enough.
6) What does it mean to have both TCP/IP and NetBeui active in the settings? Which takes precidence or do they work together?
I don't get my laptop until this week but I want to set the thing up properly. I don't want to have to go through everything again when I buy the HomePNA bridge (in a couple of weeks), or if I get a wireless setup (perhaps in a few months).
EDIT:
Oh yeah, since I'm behind the router, do I still need to unbind TCP/IP from the Microsoft File/printer sharing Client? If so, how do I do that in Windows 2000? I only see tutorials for Windows 95/98.
Some questions.
EDIT:
