JackMDS, I'd sure like to see your "foolproof" guide to setting up workgroup file and print sharing with only TCP/IP in a mixed environment of W98, W2K, and WXP computers. I have yet to discover it, and I like to think I do actually RTFM on occasion.
I agree that most of the time it will work, however I've run across the situation where after months of seemingly normal operation, the clients suddenly can't see all the shared computers in Network Neighborhood. Almost without exception, I can look in some of the event logs and find messages about browser errors. Here's a typical one on my network, which continues to function because I do use NETBEUI.
8021: The browser was unable to retrieve a list of servers from the browser master
\\BOBBI on the
network \Device\NetBT_Tcpip_{672E9906-73A2-4EF6-8C85-4EB1476D8E66}. The data is the error code.
Another popular error is:
8032: The browser service has failed to retrieve the backup list too many times on transport
\Device\Nbf_{8FA747F0-A04F-458E-8C21-3D381BE75ECE}. The backup browser is stopping.
AFAIK, the issue in a typical workgroup is the boot order and the O/S in use sets the hierarchy for the browser election, and sometimes the wheels fall off the scheme. I have yet to find anyone that has a bulletproof scheme of solving this problem that doesn't involve a local DNS or WINS server. I've heard advice to disable the master browser capability of various computers, but that only works if you can assure that the one you don't disable will always be booted to assume the role of master browser.
I suspect that if a certain order of boots and shutdowns occur, that suddenly the backup browser and master browser aren't available any longer, and for reasons that I don't understand, a new browser election is not forced. That leaves you in limbo, and I see this way more often than I should if this scheme was bulletproof.
I'm all ears, how do you get around this issue with 100% reliability? I'll bet there are others here that would like to see this solution too.
