Nero, write speed changed due to media.
creedamd
40
I have a 24x yamaha 3200e burner, yet nero switches back to 16x everytime, I have tried different brands of cd's even the expensive ones, anyone heard of such?
DeRusto
1,249
mine used to do that too, except it was from 16x to 12x on a tdk 16x burner.. i dont know why it started doing it or why it stopped..so im not much help:)
DeRusto
1,249
cd-r speed does not matter..
at least it didnt with mine..i used imation 16x cd-r and tdk 16x cd-r
both would occasionally go to 12x speeds
SuperSix
Many new burners can tell what speed the media is rated at and may adjust their speed. Some drives let you override this feature. Tried flashing the firmware?
Galactus
10
You can turn that feature off: Go to "choose recorder", in the lower left corner of that window is a button called "options". Click that, and you will find "Optimum Writespeed Control enabled". Uncheck that box, and it shouldn't bother you anymore :)
