Nero taking ages to load!!
raw1982
12
Has anyone got any suggestions that might help me out, when i try to run nero everytime it takes ages to load up i timed it, it takes me about 1 min 30.
This also makes my whole computer just freeze for this time while its loading up. And also no other program does this i even installed easy cd creator but not while nero was installed and that worked fine but i love nero. ive tried defragging my hard drive, the versio im using is nero 5.5.3.5 plextor, which came with my plextor, nero usually runs fine when it does load up i occasionally get a blue screen error and i then have to reset the computer. nero also used to run fine before i formatted my hard drive, i have the latest aspi's and the only other burning software i have installed is clonecd.
can anyone please please help!
NeoMadHatter
2,355
johntwang.com
hmm, that's weird. might need to defrag your computer. also, have you tried updating nero? i have the same cdrw as you, but nero didn't come with my cdrw, it came with easy cd creator.
