Nero Help for a noob.
MoFunk
OK I have always used EZ-CD Creator and with all I have read about nero being far better I thought I would give it a try. The one thing that I can't do for the life of me is get this thing to format a rewritable cd for drag and drop access. It wont even read the ones that I had formated before. Is there something that I am missing? Thanks.
I don't think Nero handles packet writing. You need another program called InCD that is bundled with Nero.
I may be wrong, but I think you can install a UDF reader that allows you to read the CDs created with DirectCD or inCD.
Yeah. The UDF reader is read only though. I think InCD and DirectCD both put an installation for a UDF reader on formatted discs. Computers that can't read formatted discs will be prompted to install the UDF reader first.
