Negatives for using a 3.5" to 5.25" adapter?
Ketchup
14,559
248
There is always the risk of additional vibration, especially when you are adding areas of contact. The nice thing about the one you linked is that it's plastic, which should help with that.
JimmiG
2,024
112
You could consolidate your HDD space by getting rid of some smaller, older drives and replacing them with a single bigger multi-TB drive.
Also, for SSD's, you can use Duct Tape® and stick them wherever they'll fit and the cables reach :)
Other than that, nothing wrong with the adapters.
Auric
9,591
Yeah 1:1 adapters waste space and hotswap is uber convenient (especially trayless). Could also consider 2.5" drives.
shabby
45
Why did i imagine a 5 1/4" floppy disk where you can put a 3.5" disk in it so it could be read in a 5 1/4" drive when i read the title...
mvbighead
3,793
Definitely a lot of truth to this.
However, the bracket you suggested would work and there is no real good reason not to.
sm625
8,172
137
I've used doubled sided foam tape to simply stick the SSD to the bottom of the case more times than I care to admit.
JackMDS
29,548
424
Did we even get confirmation if FrozenCPU was dead or not?
Dated 2 days ago.
Site down until further notice
July 13, 2015
FrozenCPU.com is taking phone orders between 11am threw 6pm EST. We apologize for this inconvenience. - Mark Friga Jr.
:cool:
ViRGE
Elite Member, Moderator Emeritus
167
This is an issue that quickly gets amusingly complex. The short answer is that there are a myriad of ways to fit 3.5" HDDs into 5.25" bays. However...
As someone else already mentioned, the 5.25" bays in most cases are dead zones for air circulation. Optical drives generally don't need it, so there aren't any fans in front or behind the bays to move air. For a one-off HDD this is generally fine (especially if it's a 5400 RPM drive), but if you're going to install multiple drives then you will want something providing airflow.
Which brings up larger whole bay adapters like the 5-in-3. These come in many designs, everything from simple metal racks to complex tray loaders. The important part here is finding something with a fan, and then figuring out how much you're willing to spend. The tray loaders are nice, but they are relatively expensive. Either way, you'll want to go the route of a whole bay adapter with a fan if you're looking at installing multiple HDDs into your 5.25" bays.
The Icydock technically doesn't fit. Its design doesn't account for the small rails along the bottom edge of each bay position used to hold up a 5.25" drive. Which is why there are so many comments about bending the rails.
If you don't mind bending the rails it works fine. Otherwise you may want to look at other designs that don't require modifications.
Auric
9,591
The options narrow down quickly after deciding upon tray or trayless and individual power buttons -haven't checked recently, but power are more likely available on trayless 4 to 3 than 5 to 3.
Modern drives are not likely to exceed common temperature specs (60C) without fans so they are not necessarily necessary and indeed airflow might be improved with less noise by removing them if inline with a system or SMPS fan.
Besides reviews at mongers such as amazon or newegg, check out user experiences at lime-technology and hardforum.
ViRGE
167
Dittoing Auric's advice here. The bay adapter I use is no longer made, and honestly I went cheap, which was a good idea at the time but having to remove it every time to swap drives has started to take its toll.:p
I would argue that you'll want some kind of bay adapter with a fan for more than 1 drive, but that's me being conservative (and because I put my server in a closet). If they're spaced apart and 5400 RPM drives, Auric's advice about fans is probably sound, in which case you could just do a pair of single adapters.
mfenn
22,400
www.mfenn.com
For a single drive per 5.25" bay, that's true becasue convection has enough free space to work. For anything more densely packed, you will want a fan to keep air moving across the drives. It doesn't have to be much, a big 120mm running at 600 rpm would be plenty.
piasabird
17,168
60
There are probably some adapters that will let you put 2 hard drives in a 5.25 bay or one hard drive and one 2.5 SSD.
Auric
9,591
Cooling is even less of a factor if not in constant simultaneous use -but in that case, trays may be better and drives with rotational vibration sensors.
Also, trayless 3.5" backplanes may accommodate 2.5" as well depending upon horizontal with floors for each bay, or open vertical.
