Need WiFi help with Toshiba Satellite
SBMongoos
27
Have a Toshiba Satellite 2435-S255. Installed a mini WiFi card from Broadcom that's 802.11b/g capable. This came out of another laptop of mine and I know it works and it's hardly been used.
I cannot connect to my WiFi router. I'm confident that I have the antenna corrections installed correctly. I have the switch set to on for WiFi on the side of the laptop. I've checked the Device Manager and the Broadcom Network Adapter is listed and shown as working properly. I do have MAC filtering setup on the router but I did get the MAC off of the mini WiFi and have triple check that it was entered correctly into the router. Using a DLink DI-784 which I've had no problems with my other laptop.
Any ideas? Installing this card in my girlfriends Toshiba so I can get her online.
digiram
3,991
172
Do you see any available networks when you open up the wireless adapter's properties?
SBMongoos
27
No... I did not. The laptop tells me to turn on the switch to enable the WiFi adapter. It's already on.
SBMongoos
27
Yes. I think I understand your question.
There is a switch on the side of the laptop to turn WiFi on and off. When it comes on the LED light is supposed to light up, but doesn't.
SBMongoos
27
Everything appears fine. It is listed in device manager as working. I do find it odd that I have access to the Broadcom utility and the Windows XP WiFi utility also. I have to check enable every time but I get the response to turn the WiFi switch on. Which it already is.
Delbert
1,306
The switch on the side is for a built in wi-fi adapter. Does this model have a built-in wi-fi adapter?
SBMongoos
27
No. This model is designed for a removable "Mini WiFi PCI" card. I installed one that I used in another laptop.
