This is the main problem, i am editing a tutorial video, and i used a program that captures the screen. I captured at 1024x768. This is apparently a problem since ntsc is 720x480, and parts of the screen get cut off. It also becomes very hard to read. It does look great on the computer though. I can go without fixing it for most of the video, since its centered, but there are a few parts where i am focusing on parts cut off. This is really bad, cause i have about 75 hours into this. I have access to any software i need, just tell me what to do...
Your Help Is Greatly Appreciated!
Thanks,
Brad
Edit: Guess i should tell you i am using Premiere 6.0 and I have after effects.
Thanks,
Brad
