Need video card for work comp with 305W PSU
  • Thread starter Deleted member 4644
  • Start date
D
Deleted member 4644
I need a video card for my work computer. It should have 2x DVI, or 1x DVI + 1x HDMI, or 1x DVI + 1x Displayport. Basically, I need two digital outs.
My computer is a 2.93 ghz core 2 duo, with a 305W PSU (DELL Optiplex).
What is the best video card I can buy for it -- I want to spend $50-$90, and obviously not overload the PSU. Light gaming may occur after hours.
Thanks!
cusideabelincoln
3,275
46
They're close; the 5670 is a tad faster and is basically the fastest card that does not need an external power connector.
But you should make sure you need full sized or low profile.
D
Deleted member 4644
Dell support said it can take full sized. I wonder if I have an dedicated 6pin power connector... I doubt it on a 305W PSU......
Thanks for the help BTW guys. This is exactly what I was looking for :)
Jionix
238
What Medium recommended, or wait for Turks (6650/6670) cards to arrive, which should be this month. They replaced the 5600 series with better performance/features while maintaining a max 75-watt draw (no power connector).
happy medium
14,387
480
Really? I never heard that before, got a link to the power draw and performance for those cards?
Thanks
