How industrial are you talking about here?  Keep in mind that a lot of heavy equipment can cause some heavy interference that might cause havoc with wireless devices.
Also, what are you connecting to?  If it's not a standard PC you'll have to put in wireless bridges for all the nodes.   I don't know if you can "multipoint" 8-15 remote bridges into a single central bridge or if you'd have to use a bunch of central bridges.  This means you don't get to use cheap PCMCIA/PCI cards and the price goes up quite a bit.
1000 feet is quite a ways.  You'd probably have to run fiber to get your access points located around the building so that all the devices were in contact with an AP close enough to have reasonable signal strength.  That, in itself, won't be cheap.
All in all, I agree with Spidey.  If you want the best, just run fiber and get it over with.   IF they really want wireless, make sure they understand that they won't be saving much money and will be getting something that's much slower and far less reliable.
If you do go wireless, check out
ZDNet's Enterprise Wireless homepage.  Has some pretty good resources.
- G
