Need Utility (Or A Script)
Dinsdale
9
I have a list of file names in an Excel spreadsheet, listed in a column.
I need to use this list to find files in various folders on a server, and copy these files to a new folder so I can burn a CD-R.
This could be done manually, of course, but I have nearly 1,000 file names to locate, and copy to one central location for the CD-R.
Any suggestions?
A shareware utility? Or a script of some sort? How can I do this?
It can't be THAT hard!
Thanks.
CTho9305
9,214
export it to CSV, but use tabs instead of commas.
in a command prompt:
cd the_new_folder
type thecsvfile.csv | xargs copy
You'll need cygwin xargs. You can get all of cygwin from the official site, or you can get the files you need for xargs from me:
xargs.exe
cygwin1.dll
cygintl-1.dll
Just dump them in the directory you're going to run from. I, obviously, cannot guarantee anything about those files.
CTho9305
9,214
Hmm, that doesn't work the way I'd hoped. On unix, doing a "cat foo.txt |xargs blah", for foo.txt looking like
asdf
fdsa
abcd
dcba
would run:
blah asdf
blah fdsa
blah abcd
blah dcba
I wonder if it's a cygwin newline issue, or I'm doing something wrong.
kosstamogen
68
you could write a macro in excel with VBA. You can read the cells, then jump to the directory, and I believe u should be able to copy those files also. Before I used it I didn't know how powerful the vb interface was in excel. it can do a lot...
