Need urgent help!!!
coolwww
Need some urgent help as I found my computer seemed to be controlled by some others. It?s so awful. What shall I do? I going to thanks so much if somebody help me..
Kelemvor
16,928
8
Computer was controller by some others eh? Might want to give us at least some sort of details if you want assistance.
FREDCO
The best thing to do is make sure you have a good firewall running. You can try a firewall which has Banned Sites List. Then you can enter the IP address of that computer into Banned Sites List. That computer will be blocked. Have you used Armor2net Personal Firewall? I know it has that feature. You may have a try. http://www.armor2net.com
