Need Urgent help - Antec P180 case
shreeit
68
Folks:
Anyone using P180. Please check one thing for me. how fan in back attched to the case?
I removed from it and now I don't remember type of screw used. My suspicius is there are 4 screws made of rubber was used but I am not sure. Please verify for me.
Thanks,
shreeit
Bullhonkie
1,899
The rear and top fans attach using normal metal fan screws.
I'd recommend mounting with something to help dampen/isolate them like those rubber ones. Been meaning to do this myself but still haven't gotten around to it.
Shadowknight
3,959
If you want to softmount, Jab-tech sells some isolators for around $1.30 for a pack of 4. I don't know how good they are vs. Verax's (which is more expensive, but better than the commonly used EAR mounts).
potato28
8,964
Just dont buy the Sunbeam ones... Zap and a few others have had major problems with them.
