I really like my APC 750VA, model BE725BB. I originally had the
APC 725VA UPS, but it made a really loud buzzing noise. I immediately contacted APC's online tech. support on Dec. 25th. They replied within 24 hours even though it was Christmas! They said the UPS shouldn't be making noise, and they asked for my address.
I responded with the requested info, and the guy then told me to expect a replacement in 3-5 business days, along with a UPS pre-paid shipping label to return the faulty unit.
I was even more surprised when I opened the box and found a brand new APC 750VA UPS...they upgraded me to a model that isn't even in stores yet! It's silent like other APC UPSs I've used, and it powers all of this for about 15 minutes:
Abit NF7-S 2.0
Athlon XP 2500+ w/Retail hsf
Kingston 2x512mb HyperX PC3200 @ 2-2-2-11
ATI Radeon 9800 Pro 128mb
Sound Blaster Audigy 2 ZS
Western Digital 74gb Raptor
Black NEC 3500A 16x DVD+/-RW
Black Lite-On 52x32x52x16 Combo Drive
Blue 6" Cold Cathode
Logitech Elite keyboard
Logitech MX500
Enermax 460W Blue dual fan power supply
Viewsonic G90fb 19" CRT
and a
Netgear MR814 v.3 router (so my network doesn't go down when the power flickers during thunderstorms).
I Googled the problem I had and found
this thread, in which some other guy had the same problem and also received a 750VA (but after three 725VA RMAs...they apparently didn't understand the problem then). The thread has a link to an
official statement from APC that declares the problem.
According to
this page, even a dual Opteron computer pulls under 360W at load, and a typical A64 gaming computer will consume less than 220W under full load. Compare your server to the machines on the review I linked you and that should help you guess how much power you're using.
I didn't install the software that came with my APC UPS because when I plugged in the USB cable that came with the UPS, Windows XP automatically detected and installed it. I can control the actions the computer will take by going into Power Options in Control Panel. XP set it up by default to display a warning when the battery is at 50%, and then automatically put the computer into hibernate at 10%. It can be set to shut down instead of hibernate if you want.
You'll only be able to automatically shut down one computer with one UPS I think. Maybe you should get two UPSs.
