Need Upgrade Advice
Jerm324
Hello all, I'm having upgrade difficulties, and was hoping y'all could help.
Due to the fact that I can only spend about $500 at a time I'll have to do my upgrade in waves. I'm trying to decide whether to first upgrade my video card to a 6800 GT ~$400, or doing a CPU/Mobo upgrade first ~$450. I'm set on getting a A64 3500+ 90nm Winchester for my CPU and a nice HSF to match. However I'm divided on the mobo to get. I've narrowed it down to the two below. What do y'all think? Video card or CPU/Mobo first, and which mobo do ya think is better, the MSI or ASUS? I won't be using the onboard audio so disregard that.
MSI "K8N Neo2 Platinum" NVIDIA nForce3 ULTRA Chipset Motherboard For AMD Socket 939 CPU
- Specifications -
Supported CPU: Socket 939 AMD Athlon 64FX/64 processor
Chipset: nForce3 ULTRA
RAM: 4x DIMM Supports dual channel DDR266/333/400 Max 4GB
Slots: 1x AGP 4X/8X, 5x PCI
Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1x IEEE1394, 2xRJ45, 1x S/PDIF Out, Audio Ports
IDE: 2x ATA 133 up to 4 Devices
SATA/RAID: 4x SATA RAID with 0,1,0+1
Onboard Audio: ALC850 8-Ch
Onboard LAN: Marvell 88E1111 1000Mbps, Realtek 8110S 1000Mbps
Onboard IEEE1394: 3x ports by VIA 6306
Form Factor: ATX
ASUS "A8V Deluxe" VIA K8T800 Pro Chipset Motherboard For AMD Socket 939 CPU
- Specifications -
Supported CPU: AMD Athlon 64/Athlon 64 FX
Chipset: K8T800Pro + VT8237
RAM: 4x DIMM Dual Channel DDR400/333/266 Max 4GB
Slots: 1x AGP 8X, 5x PCI
Ports: 2x PS/2,1x COM,1x LPT,8x USB2.0(Rear 4),1x IEEE1394,1x RJ45,2x S/PDIF out,Audio Ports
IDE: 2x ATA 133 up to 4 Devices, 1x ATA 133 up to 2 Devices by Promise 20378 with RAID 0/1/0+1
SATA: 2x Serial ATA with RAID 0/1, 2x Serial ATA by Promise 20378 with RAID 0/1/0+1
Onboard Audio: Realtek ALC850 8-CH
Onboard LAN: Marvell 88E8001 GbE
Onboard IEEE1394: 2x 1394 ports
Form Factor: ATX
What do you have now? What are your expectations for your games (for example, do you require 16x12 with everything above maximum settings, or can you make do with 12x10 high settings)?
Currently I have and Athlon XP 3200+ on an A7N8X-E (NF2), with a Geforce 5900
I always like to play with the best settings possible, 12x10 is fine but I like to play on the highest detail settings possible. I'm also wondering which of the upgrades will drop in price faster with time.
