Hi,
I've had an ATI-based X1300 video card (Sapphire) for the last ~2 years and it has been working great.
Recently, I've obtained a 2nd LCD monitor which I want to connect through DVI instead of VGA (the Sapphire has 1 DVI and 1 VGA connector).
I want to upgrade my card but don't want to spend a lot (maybe buying something off the F/S forums here); it must have dual DVI and also be a step up or two from my old card.
What do you guys recommend? Should I stick with an ATI-based chipset or move to an NVIDIA chipset?
Thanks a lot!
Thanks a lot!
