Need TV card that will work with G400 Max DH on W2k
DroppedAtBirth
8
I am currenly running a Matrox G400 Max DH 32mb with dual display at different resolutions. I had a Hauppauge WinTV card but it won't work with the G400. I need a TV card that will work it it. Any ideas??
Vegito
8,329
How does it not work ? No pic or driver issue ? I have the pinnacly system old PCI TV card.. works fine...
EvilDonnyboy
Banned
Jul 28, 2000
1,103
I'm not sure why the Haupauge WinTV card isn't working, but I can recommend the Rainbow Runner for G series, but Matrox. This little card has just about everything, including MJPEG hardware acclerated compression, a full set of composite/S-video input/outputs, and more stuffs. Easily the best consumer grade TV add-on for the G400/MAX. Which should be expected, since Matrox made it themselves.
If the RR is too expensive or you can't find 'em, I believe the ATi TV Wonder VE should work with the G400.
For you're Haupauge problems, go to Matrox's Official Support Forums.
