imported_wjh
Please help me troubleshoot and fix this strange video problem. Every few minutes the monitor will flash-- the screen becomes completely dark for around one second and then returns to normal. this happens once or twice then everything is normal until the same thing happens a few minutes later. There is no apparent damage done, everything seems to work normally before and after the flashing.
My System: Win XP Pro sp2 + all hotfixes, FX-55, MSI K8N Neo2 Platinum MoBo (MS-7025) Phoenix - AwardBIOS v6.00PG, 2 X 512 MB OCZ PC3200 Platinum Rev. 2 RAM, Gainward GeForce 6800 GT Golden Sample normal settings, 160 GB SATA and 120 GB PATA HDDs, Dual Monitors 21" Triniton Tube CRT and 20" LCD.
Prime 95 - Stable Overnight, PC Mark 05 - 4918 (avg of 5 runs) BTW -- Would I see much performance increase by going to 4 X 512 MB of RAM? If I did this, should I get more of the same RAM? ( the Rev. 2).
Thank You!
Best,
Walter.
Thank You!
Best,
Walter.
