Need tripple monitor wall mount.
SirGCal
I'm pondering the change of my setup to a trio of the new 27" ASUS VG278HE gaming 144Hz monitors. But I want them wall mounted in the nice arc on one mount so they don't get independently moved around. Mount must also have a nice extension from the wall and some move-ability (while mounted, not move-ability like moving to another location all together).
I can't find anything that will handle monitors this large. They're only (under) 18 lbs each so it's not weight either. I've got many wall mounted and extended items well over 100 lbs. It just seems the manufacturers stopped at 24" monitor groups.
I've got plenty of graphics power with an overclocked 7970 and going to get a second if I do this setup and bump up the power supply a bit but... If I can't get it wall mounted, I'll stick with a single for now.
http://www.newegg.com/Product/Produc...82E16824236293
