Hi,
I have a few of those "clip-on" surround sound speakers (2 sets of 2), you know the ones you usually connect to an amp? Well, I dont want to buy another amp, but I want to connect them to my desktop (only one set). Can I do the following:
1. Take a composite cable (the red, white, and yellow cable), rip-off the yellow and throw it away.
2. Cut the connectors off of one end of the cable--the red and white connectors; strip the wire, and clip it to the clips on the speakers--the red on one of them, and the white on the other.
3. connect the other end to this converter:
http://cgi.ebay.com/Logitech-5...ms=72%3A1205%7C66%3A2%
7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
4. Then connect one end to a 3.5mm audio cable, and then that into my desktop?
Another question, since it wont be connected to an amp will I be able to control the volume of the speakers? I know that for certain speakers Vista doesn't let me control the volume, its kind of fail, because my macbook pro, lets me control the volume just fine
I plan to use the other set on my macbook pro, so yeah...
Thanks for the help guys!!
