Need to remoce Coke stains from car seat. What to use?
AnyMal
15,780
My 4 y/o daughter spilled some Coke on her car seat and now there are some nasty dark spots on the beige cloth seat. What should I use to remove it?
ElFenix
102,389
8,547
Originally posted by: AnyMal
Originally posted by: ElFenix
baking soda
Sprinkle soda and wipe with wet rag? Should I let it soak first?
i'd cake it on there pretty solidly and then vacuum it up.
you migth also try some oxyclean.
edit: if it's still wet i'd used caked on baking soda. if not wet, mix soda with water and then use a shop vac.
Tyrant222
802
woolite is good. My car has a black interior. First thing I did when i got it was spray it down with woolite. I saw coffee and soda stains rising up after I did that. Make sure and use a wet rag afterwards to wipe away the stains.
sandorski
70,621
6,184
Originally posted by: jadinolf
Yes, the OP asked for the Coke comments. :(
He sure did! Good thing "Tranny" wasn't involved in the title or all hell would have broken loose!! :Q :D
Farang
10,913
Originally posted by: SmoochyTX
How does remoceing work? :D
I hearby decree that typos, in which the faulty letter is but one key away from the correct letter, shall be deemed acceptable and shall not be commented on any further by the responders of the thread.
