Need to make toast without a toaster - oven or stove top?
coaster831
152
Use the broiler setting on your oven, and place the toast on a pan on the rack closest to the broiler. Flip halfway through to achieve browning on both sides.
Edit: If you have a gas range, you may have to toast directly on the oven racks, since the broiler is probably on the bottom. Electric ranges usually have the broiler at the top.
Mar 15, 2003
12,668
103
Sweeet.. Thanks coaster!
Kelemvor
16,928
8
I'd say the broiler as well. Just like making that frozen garlic bread. Can ehat it for a bit to heat it up and then put it up by the broiler to get it toasty brown.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Depending on what you want added to your toast.
To just toast bread, a frying pan on the stove is more economical.
GuitarDaddy
11,465
Iron skillet on the stove top. Oven broiler is a waste of time and energy unless your toasting alot of bread.
Almost as difficult as boiling water:confused:
Mar 15, 2003
12,668
103
started with the broiler but it took too long so I went the stove top route..
Yes, yes - I'll get a toaster tomorrow... I just rarely toast!
tfinch2
22,114
Put a little butter and make it grilled.
