Need to make a brochure. Help me out PLEASE!!
jcovercash
9,064
What is a good program to use to make brochures? I have tried word and it doesnt work how i want it too. Maybe if someone could point me to some good layouts that might help.
Thanks,
Josh
Dhruv
729
Thanks,
Josh
Sure. I made brochures for our company in Adobe Pagemaker 7.0. A lot of ppl like Quark Express, but AP was fine enuff for me. Its really good at that and relatively simple to figure out. Couple points i learned: if you insert like a company logo or something make it a .tif not .eps or anything else before you insert. Word is really limited. You can buy it, or get a 'trial' copy from kazaalite.
g luck
bizmark
Banned
Feb 4, 2002
2,311
I would second the PageMaker suggestion. It's really pretty powerful and easy to use.
