Hi,
i finally made a decision,..
I bought the ZALMAN CNPS7000A-Cu
and
VGA Silencer Revision 3
now i need to know how do i remove the stock hsf on my Prescott cpu and Radeon 9800pro so that i can put these little baby on.
both of them were purchased less than a week. I have intel thermal pad sticked on my hsf... so how should i completely totally remove the pad?
also the Radeon 9800pro, i didn't install the hsf onto it, it came with it, i believe it has thermal paste, so how should i remove that also.?
I have bought a 5.25" bay FAN drive will u install it on the top slot? or lowest slot? I have only an cdrw drive. I was thinking putting it on the top slot, so it can somehow has some air going throw the ddr ram(cuz it is hot either), then where should i install my optical drive(cdrw)?
and i have a harddrive fan, it only has 2200rpm, is it enough?
first impression to the CNPS7000A-Cu(before i've seen it), i thought it is small and light however there are many position reviews. Once i got it in hand, wow, the all copper version is heavy. Weighting 773g. now i may need to think of a way to divide some weight.
thanks
and
thanks
