Need to hang comforters from concrete wall
TechBoyJK
16,699
60
I'm going to hang some comforters up in my basement to help with sound absorption.
The walls are the basement foundation walls, so they are concrete. I can screw into them, but not nail.
If I screw into the comforter, it's probably just going to chew it up. So I'm trying to think of a way to hang them without screwing them up to much.
I was thinking some kind of hardware that could be screwed in, and has a hook or pin that I could just hang the comforter from. Any ideas?
zinfamous
111,678
30,997
can you sew?
just sew some loops along the edge of the comforter, loop around wall screws.
real men can sew.
Bignate603
13,897
Go to your local hardware store, they will have plenty of hooks that can be attached to the walls using screws. It's a really common thing that people buy.
iGas
6,240
Rent a Bosch/Hilti hammer drill at home depot, get a 3/16" hammer drill bit, bailing wire, #10/#12/0.25 Fender washers or rivets, and 3" double head common nails. Or, screw anchors, or smackies.
Drill holes in concrete, and use any of the hardware combinations below to mount the comforters (punch holes right through the comforters).
Rotary&
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
You guys act like no one in the history of the world ever faced this situation before. Go to a sewing or dedicated quilting shop and ask for quilt hanging ideas.
32,663
Why? We already solved the problem. Wall=>hole=>anchor=>screw=> grommet=>comforter=>crappy stereo playing awful music
32,663
Tell the truth, you still use milk crates for shelving don't you?
Not anymore. I peaked at 41. I used to have a complete bedroom suite plus bookshelves and end tables in the living room. I've moved up in the world though. Now I use Rubbermaid storage bins.
lxskllr
59,252
9,755
You don't even have to sew. Put a small ball/stone/whatever in the corner of the blanket, tie cord around it, then tie another looped cord around that. Attach to wall, or preferably hang from joist.
Edit:
Added small word. I don't know what my problem is lately, but thoughts don't make it from my brain to my fingers. I drop whole words out of a written thought :^/
32,663
Hot glue it to the wall. It's all good.
Also, think through whether or not you want to drill holes in your parents' foundation (or, more importantly do your parents want you doing that).
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
And then staple egg cartons on the ceiling, paint em flat black and, hang blacklights for your 'epic' posters. Don't forget the lava lamps.
Imp
18,828
184
Relatively warm, moist air meeting cold concrete wall face = enjoy the mold.
iGas
6,240
Stones or sticks are way to hang if the tarp grommets are torn off.
Perhaps duct tape would also work for this situation.
Or, we could go for the gusto, and use MagnusTheBrewer suggestion for a full blown sound dampening the room by build a room within the room (no contact point) ,with air space and sound insulate both sides of the existing wall/ceiling and suspended internal structure, then shape the internal wall with sound absorbent material.
Modelworks
16,240
7
Take a small gauge wire , like a 22 solid and push it through the comforter edge and tie in a loop, then you can hang from a nail or screw.
32,663
Head down to the used store display store and buy some manikins. Tie the comforters to the manikins' hands and pose them such as to hold the comforter up against the walls. Optional: dress the manikins as gangbangers.
