Need to fix my Technics SL-P100 cd player.
BigToque
11,700
The "open/close" button doesnt work on this player.
I'm positive the problem is electronic (as in nothing is jammed or stuck).
I've got it open in front of me, and I can physically put in and take out cd's and they play fine, I just cant get the tray to open.
If worse comes to worse, I can borrow one from a friend, but I'd rather fix it.
I dont know much about the actual electronics, but if someone had any idea what I would need to do, I do have the skills to solder resistors and such. (took an electronics class in grade 9 before)
Or...
What would it cost to fix the button at a shop?
BigToque
11,700
I fixed it! after 3 and a half hours I figured out what was wrong!!
GOD DAMNIT I HATE WHEN THE ANSWER IS SO EASY AND YOU JUST DONT GET IT!!!
