Need to encode ID3V2 info onto MP3s
tweakmm
18,436
4
I use EAC to rip my mp3s and then Razer lame -remix VBR to encode them, but no ID3V2 tags are written into the mp3s, is there any way that I can have them written in automaticly?
Oscar1613
1,424
theres a good program called Tag N Rename for mass ID3 tag and/or filename conversions... it'll take the filename and find the artist and title (etc) and write it to the ID3 tag (or vice versa), but i dont remember where i got it from... search around on cnet or google and you should find it in no time
ddjkdg
718
I've never used EAC or Razer lame but if you rip with Easy CD-DA Extractor you can output the files with ID3v1/v2 tags easily...
PliotronX
8,883
107
EAC can automatically generate ID3v1 or 2 tags. Try playing with the compression options under "ID3 Tags" tab.
