Here is my rig:
Athlon 64 3200+
512 mb DDR PC3200
Geforce 3 Ti200
60 gig Maxtor Hard drive
300 watt antec power supply
Windows 2k pro
The issue:
I have been getting stop error 0x0000007f(0x0000000, 0x0000000, 0x0000000, 0x0000000) which leads me to believe I have either bad memory, or a bad power supply. If I had more $ I would just go about replaceing both, but I don't. I need a surefire way to eliminate one or the other as the issue. I have been running Prime95 and it hasn't come up with any memory issues, but I'm not sure how accurate that program is. The problem is after my comp runs for 30 min. to an hour if I open up anything related to IE my comp crashes and gives me the above error. It will then reboot exactly 3 times before it will stop giving me that error and starts the whole thing over again. Any good ways test one or the other or both? Thanks.
Brett
Athlon 64 3200+
512 mb DDR PC3200
Geforce 3 Ti200
Windows 2k pro
The issue:
Brett
