Need to copy files from 1 hard drive to another
GoodEnough
1,547
19
I want to copy 30GB of files from SATA HD #1 to SATA HD #2.
My desktop PC needs one SATA ribbon for the Win7 OS.
It has one other spare SATA ribbon.
I could disconnect my DVD Drive for the 2nd SATA, but the cable is not long and I'd have to somehow dangle the HD.
What are some options?
Get a USB enclosure for drive #2?
Will USB be too slow?
boomerang
18,883
641
Just dangle it. You should be able to find a means to give it some support for the duration of the copying process. I've done it lots of times. Just don't let any circuitry make contact with any conductive surface. Or, you're talking about getting an enclosure, just get a longer SATA cable.
Fardringle
9,200
765
Sit it on a book, cardboard box, or something else that is not conductive that will keep the second hard drive supported at a height that won't put too much strain on the SATA port/cable.
GoodEnough
1,547
19
I will try the prop it up method, but I might as well get a enclosure for times I want to actually access the files, and use the external drive.
I like to keep rarely accessed archive drives unconnected, to increase drive life.
Is that a generally sound idea?
bruceb
8,874
111
I keep my external drive connected to the USB Hub at all times. But the Power to the Drive (a small dc adapter) stays OFF until I need to use the drive. You should have no issues connecting it to the SATA cable without an enclosure. If you do it via USB expect it to take a while to move 30GB of data.
GoodEnough
1,547
19
Can someone recommend a USB enclosure for a 3.5" Desktop SATA drive?
Not sure if Ebay ones are junk, and too many choices.
bruceb
8,874
111
Corky had suggested this one a while back:
http://www.newegg.com/Product/Produ..._drive_docking_station-_-17-707-380-_-Product
  • Universal docking station lets you connect an IDE and a SATA 2.5"/3.5" HDD or SSD to your computer
  • USB 3.0 with UASP for optimal performance
  • Replacement for UNIDOCK3U & UNIDOCK3UEU
It runs about $80
bruceb
8,874
111
That one is not available at present. And it only holds one drive. The Startech can hold 2
Charlie98
6,298
64
The OP only has one drive... and he can buy two for less than one of the Startech cradles... :D
Burpo delivered the goods.... :thumbsup:
bruceb
8,874
111
He can buy whichever one he wants. The Startech can also do IDE type drives and SSD drives. The one you linked to does not do IDE and I am not sure if it can see a SSD ... Also the Startech has individual drive Power ON / OFF buttons.
Charlie98
6,298
64
Yes, it does both 2.5" and 3.5" drives, spinners or SSD. The power switch is on the back. It does not do IDE drives... so you got me there. But the Xigma is in trendy white with cool ventilation and a streamlined case, for better MPG. $25 vs $80... o_O
mikeymikec
20,958
16,192
When I want to do something similar to this, I tend to have the tower standing upright, then a stable object next to open side of the tower of the correct height to sit the extra hard disk on.
lakedude
2,778
529
I like to use some type of adapter or enclosure for work like this, especially if there is a chance that there will be more than one bootable drive. I like to get the system booted up from the OS of choice and plug extra drives in after the system is completely up so there is no chance of any boot confusion.
I could be mistaken but I seem to recall a system that booted using parts of 2 different disks and generally making a mess of things.
That Star Tech IDE/3.5/2.5/SATA/USB thing looks cool but it is a bit expensive IMHO.
LTC8K6
28,520
1,576
I've always done it basically that way.
Never had a problem.
bigboxes
42,206
12,413
It runs about $80
I may have to look into adding that to my options when it comes to back ups. I still have a stack of HDDs, both SATA and IDE, lying around. Also, good for testing.
I've used external enclosures for quite a while.
MrTeal
3,919
2,708
Just dangle it, or if that just feels a bit too hairy shove a box beside it. Hard drives are not damaged by alternate orientations, it will be fine.
