zug134zwang
I have about 800 old (10-30 years) standard vcr tapes recorded at 6 hours per tape. I am going to attempt to transfer the videos to my hard disk. My previous vcrs had all died, so I recently purchased a Mitsubishi HS-U746 (4 head) used vcr at Amazon. I also purchased a video capture card that requires S-Video input, and the HS-U746 does provide S-Video output.
Before attempting to use the HS-U746, I took it directly to a vcr repairman. He stated that I got lucky; the HS-U746 is in good working order. In his shop, I watched as he verified (with his own vcr tape) that the vcr's record and playback functions are all fine.
At home, I connected my cable box to the vcr with a coaxial cable and then connected the vcr to my (old) tv with a coaxial cable. The cable box signal goes through the vcr to the tv okay and I am able to watch all my cable channels. However, when I attempted to play a vcr tape, all I got was static (audio and video). Just in case, I also connected the composite (red-white-yellow) cables from the vcr to the tv. Again, the cable box signal plays ok while vcr playback gives static.
Experimenting while attempting to play a vcr tape, I hit the fast-forward button : the video displays okay. With a similar experiment with the rewind button, the video also displays okay. I also experimented by using the vcr's record button to record for about 15 seconds. No joy, its playback is also static.
I chose 5 different vcr tapes at random and repeated these experiments; the results were identical. I am relatively ignorant in this area. My black-box-testing inference is that my 800 vcr tapes all need to be re-tensioned. If I can't find a way to do this relatively cheaply, at home, then I will discard the tapes and abandon the project. Also, I question the advisability of using the HS-U746 to fast-forward/rewind each of the 800 old vcr tapes (perhaps 5 times for each vcr tape).
Questions
1. Do you agree with my inference that the problem is tension in the vcr tapes? If not, what do you think the problem is?
2. If so, is it plausible that performing fast-forward/rewind 5 times will re-tension one of my old vcr tapes so that it will playback okay in the HS-U746? If not, is there a cheap and feasible way for me to re-tension each tape before I play it in the HS-U746?
3. If so, is there a cheap hardware unit designed specifically for performing a fast-forward rewind on a vcr tape? Tentatively, I would fast-forward rewind 5 times on each vcr tape before attempting to play that vcr tape.
Questions
