Need to allow only two specific USB removable drives on a system
slicksilver
1,571
is there anyway to do this? I have two kingston usb drives and would like only them to work. No other USB removable disks should have access to the system. Is there any software to do this? Freeware or paid does not matter.
Thanks.
Modelworks
16,240
7
Depends on what you are using the drives for. Are applications running off the drive or are they being used for just copying files ?
