Need to add a 3rd ROM drive - Do I need a PCI card?
waylman
3,473
I already have a CDRW and DVD +/- RW and need to add a DVD ROM. I also already have 2 HD's. Do I need a PCI Card to add the DVD ROM? If so, can someone point me in the right direction on NewEgg because I'm not finding what I think I need there. Thanks alot.
solution found:
Everyone, I came up with the perfect solution! I don't need a 3rd optical drive, Im just going to get a CDRW/DVD ROM combo drive.
Why did no one think of this?!?!
DVD ROM/CDRW will be used for burning CD's/CDROM/ripping DVD's
DVDRW will burn DVD's
anyone have a good recommendation for combo drive?
Flyermax2k3
3,204
If you have no more IDE ports on your motherboard, you'll need to get an IDE/ATA PCI controller card. Then add storage/optical devices 'till your heart's content!
waylman
3,473
cool, thanks. Also, is it faster if the device goes through IDE or the PCI card?
Ronstang
12,493
18
That depends upon the quality of the IDE controller on your mobo, only testing will give you the answer to your question. On one of my older machines I use the PCI card for all the HDs because after testing with HD Tach it was shown to be much faster than the built in controller but every case will be different so test it and see for yourself.
ViRGE
Elite Member, Moderator Emeritus
167
Go to the CD/DVD section(it's divided up between burners and not burners, so pick accordingly), and then use the left-hand panel to do an advanced search, selecting "external" as the interface, and leaving everything else alone.
josphII
Banned
Nov 24, 2001
1,490
why do you have a dvdrw and a cdrw? most dvdrw drives also have cdrw capability, yours doesnt?
Shawn
32,236
53
I have both in my computer too because I use my cdrw as my cd rom drive too. The only thing I use my dvd-rom for is strictly burning dvds.
Thraxen
4,683
have both in my computer too because I I use my cdrw as my cd rom drive too. The only thing I use my dvd-rom for is strictly burning dvds.
Same here. I replaced my DVD-ROM with a DVD+/-RW and already had a CD-RW. I saw no need to get rid of a perfectly good CD-RW. So my CD-RW handles all CD reading and writing duties while my DVD burner is just used to burn and read DVDs.
waylman
3,473
yeah, my dvd burner does cd burning also, but only at 16X. I want a DVD ROM for ripping DVDs to my HD at a high speed. Thus, the need for 3 optical drives.
WinkOsmosis
Banned
Sep 18, 2002
13,990
Haha. Don't want to wear out your DVD burner? Then use the DVD drive for CDs when you get it and get rid of that CDRW.
Farbio
3,855
what if you have raid ide slots on your mb? can you use those as well?
i'm curious myself as well....i'm out of normal ide slots as well
and for the curious, i have a dvdrom, a 52x cdrw, and a 16x cdrw. i hate using the 16x cdrw, but its a plex, and the only type that will burn cd+g format, which i need for business. i refuse to have burning at only 16x forever though, and since i have a 52x liteon, seems kinda dumb to buy a 52x plex
Zim Hosein
Super Moderator | Elite Member
65,400
407
Yes, you can use your RAID IDE connections Farbio. That's what I do :)
Shawn
32,236
53
same here. that was the main reason I got raid. freed up a PCI slot. ;)
Shawn
32,236
53
lol, my DVD player refuses to read normal cds half the time. and when it does work it's so slow. it reads at around 6x according to SiSoft sandra.
waylman
3,473
