AnonymouseUser
Originally posted by: dxkj
Also trying to figure out which cordless drill to get, i currently just have a corded black and decker.
I recently bought a new 18V cordless drill. My previous drill was a 7 year old 12V Milwaukee (used daily, original batteries), and I was quite impressed with that drill. Needless to say I intended to get another Milwaukee drill. That was until I met the new Makita drill...
18V, Lithium Ion battery, 15 minute charger, built-in light etc., but the best feature of all was the weight. This 18V drill weighs less (3.5lbs) than my previous 12V drill (4.3lbs)! I never thought I would buy anything other than a Milwaukee, but Makita changed my mind. The only downfall is the battery's capacity (1.5AH). That helps keep the weight down, but the 15-minute charger more than makes up for it's limited capacity.
$200 of pure bliss
how long does one battery last? I notice it comes with 2
That totally depends on how you use it. I can go almost a week on one charge (medium duty use), which is about the same as my 12V Milwaukee used to last. You can always get the 3.0ah batteries if you need them.
