stealthshadow
Hey guys I am new here and I need your help.
Im considering buying a new PC, and after searching the web I decided to buy this gateway PC
http://www.bestbuy.com/site/olspage.jsp...yId=pcmcat73200050029&id=1130986103611
Can you please tell me the positives and negatives for this PC? I plan to play a lot of games and just use the computer normally.
I plan to upgrade the graphics to a Nvidia 6800 GS from EVGA to make it a good gaming PC. THe only problem is that the PC only has 300 watt power supply is that ok for this graphic card?
THe other thing is that I was wondering if the harddrive is good enough? It says that it is only 2mb cache, is that REALLY bad, will that bottleneck the system? I do'nt know anything about harddrives so if someone can explain to me how that will affect my system that would be great.
Last thing is that i have around 1400 and am trying to get the best gaming computer possible without actually building one, so if you know any other models (preferabbly AMD) please suggest.
The main issues id like you to answer though are your thoughts about the computer, the hardrive issue, the powersupply issue, and whether i will be able to run all the current games on everything on high?
THank you for your time.
