Need suggestions for Network solution
kalren
11
Well, In the next few days I'll be getting a second computer along with a ethernet cad for my Dreamcast. And in my current setup, my cable modem(Static IP) is simply connected to my LAN card in my main computer.
My question is what do I need to get all three machines(2 PCs and 1 DC) connected to my cable modem? I should also note that getting a second IP is available to me at no cost(I think).
Do I just need a Hub/Switch? Or do I need something more?
Thanks in Advance!
outlamd
79
You could go with a Linksys 4-port router/switch. This will allow you to use the single IP you have, and network your machines either through staticaly assigned addresses or DHCP. Does the Dreamcast support DHCP?
bighurtx82
206
Outlamd is correct. A Linksys 4-port switch/router would be sufficient for your use. Plus I have never had a problem with any Linksys product that I have purchased.
sun818
1,147
If you want all three computers to access the Internet, you will need to invest in a hardware or software router. The LinkSys Router with 4-port switch ($150) will work. Also, consider the SMC Barricade for the same price. SMC has better live technical support (24/7) and the router comes with a print server.
On the software end, you can use one of your computers to act as the Internet Gateway and configure ICS (Internet Connection Share) for Win98SE/Win2k. This costs nothing, but you will need the ICS computer on for the others two have Internet access.
I hope this helps.
Thanks,
Sun
