- Jan 29, 2005
- 5,202
- 216
- 106
Alright, so I've decided on the parts for my upcoming upgrade.
It will be:
Gigabyte GA-X38-DQ6
Corsair DDR-2 CM2X1024 8500C5 5-5-5-15
The processor will be a Penryn in early 2008, as soon as available, I will get one of the slower models (maybe a 2.4Ghz or 2.6Ghz model, or anything along those lines), but I can buy the parts above very soon (in fact I should) since I have a 10% rebate for them.
Now the questions are:
1) Is it "ok" to go with DDR-2 and X38 ?
2) The Corsair memory mentioned above is listed on Gigabyte's Supported Memory list for that specific motherboard, which is cool, but let's pretend for a moment that I just can't find anymore of that specific memory model, and let's pretend I buy something that is not on that supported list, does that mean it just won't work, or does that mean that if it ain't stable or not 100% compatible then Gigabyte holds no responsibilities about whatever could happen ?
And, overall, you guys think I'll be good with that for two or three years ? Sorry to ask, but I don't know much about hardware, except for basic OC'ing, I'm more into software stuff.
Thanks for your time and help.
It will be:
Gigabyte GA-X38-DQ6
