Need Suggestions for Liquid Cooling
Aiden2k13
Hi, need suggestions on liquid cooling. Currently I have Corsair H100i and it got damaged. Out of the two pipes, one pipe is getting huge heat and the other one is not getting so heat. Also, when I am playing games like CSGO , Just Cause 3 , the temperatures are near 90-92 C despite of reapplying a new thermal paste. So, the hardware guy told me to get a new cooling system but I need suggestion as which one should I get now.
My mobo is Gigabyte Z97x gaming G1 wifi bk and CPU is i7 4771.
So which liquid cooling should I get for my system ?
Thanks in advance 🙂
HeatKiller 3.0 - $89 USD
Swiftech MCR320 Drive Rev3 with integrated Pump and Res $169 USD
bought all my parts from Frozen CPU - no issues. Paid using paypal
All you need then is tubing and some tube fittings. I would do 1/2 inner diameter, and 5/8 OD
Testing my W3690 (6 core) @ 4.6GHz & 1.375v it peaked at 71*c on the hottest core. That's with the pump at 35% running speed. If I had it at 100% the cores would probably stay under 65*c. Testing done in 76*F ambient temps.
