Originally posted by: lenjack
If the speaker is old, the problem might be deterioration of the foam which is common. It may not be the adhesive at all. Refoaming kits are available.
Most likely polypropylene. You know, just about any epoxy will do the job just fine. It's what I've used in cases like yours. Also, you can get clear epoxy, which never hurts.Originally posted by: Budarow
Also, the cones are NOT paper but some sort of synthetic material. I've forgotten the "technical" description.
Originally posted by: stogez
You could probably use any clear epoxy for them. Just put pressure on it as the epoxy is drying so you dont get any bubbles and you should be fine.
@Fike caulk would probably come off when the speakers are being used. Its a speaker...you WANT the vibration![]()
silicone may not be the optimum, but I am not sure I agree about your statement that you want to transmit vibration to the enclosure. Vibration should be transmitted by moving air with the cone, not the vibration of the whole enclosure. that is why good speakers are so heavy; the enclosure provides dampening of unwanted vibration.
Originally posted by: MS Dawn
You want a cement with high tack strength, low viscosity, and very light. Adding mass to a driver is very bad. Seal All works well.
I had a driver that had the surround damaged when a prop was was pushed into the front of the cabinet and that's all I had to glue it back. The surround was separated for about an inch - too big to ignore. Very thin beads were applied to both sides and allowed to dry for a few minutes and then it was pressed together. That speaker still works today and gets played HARD.
If you have old speakers with crumbling foam surrounds, you will need kits to replace them OR you can send the drivers to a re-coning service.
Check these guys out.![]()
