Hi, I need a little advice about getting a Tv tuner/ recorder card. I'll only be recording analog tv signals through a DirecTV reciever. I was thinking about getting a Happauge 350 capture card since it has a hardware encoding chip on it.
My question though is would I be able to use my computer (play Battle Field 2 etc) while recording using said card? I can record Tv using my Geforce7800GT but it seems to use software encoding and if I try to use the computer while recording with it the video I've recorded ends up out of sync with the audio.
Here's my spec's
Processor: Amd Atholon XP 3700+ (San Diego core)
Ram: OCZ Dual Platinum PC3200 Ram (2gigs)
Motherboard: Asus A8N-Sli premium
Video: Evga Geforce 7800GT
Audio: Soundblaster X-fi xtrememusic
Hard drives: 1 Seagate 7800.2 120GB hard drive 2second drive 160GB Seagate 7800.8 (both 7200 Rpms) The first drive has windows X.P on it and my apps(web browser etc.) and the temp and swap files (in a separate partition)
The second drive has my games(one partition) and the space where I store video to (another partition) when I record I record to the first physical disk.
OS: Windows X.P home.
Here's my spec's
